slow leak in tire rim seal
   / slow leak in tire rim seal #1
simonmeridew
Northeastern Vermont
Kubota L4400
What can I do to seal slow leaks around my tire rims on my Polaris 500 sportster? They take a couple of weeks and loose at least half the air pressure. BTW what air pressure should I be running?
   / slow leak in tire rim seal #3
Slime.
The PSI depends on the tires you are running. Actually the tire should tell you the proper PSI right on the sidewall.
   / slow leak in tire rim seal #4
Slime.
   / slow leak in tire rim seal #5
Break the bead and check for rust, clean up with a wire brush on an angle grinder.
I stopped using the slime stuff. When you change a tire or have to pull a tire you will understand why.
   / slow leak in tire rim seal #6
   / slow leak in tire rim seal #7
</font><font color="blueclass=small">( Break the bead and check for rust, clean up with a wire brush on an angle grinder )</font> then rub a little grease in inside of rim,
when I was in high school, working at the gas station we has a can of something at the tire changer that we would brush on the bead to help seal them. Anybody know what they used back then, mid-late 70's
   / slow leak in tire rim seal #8
   / slow leak in tire rim seal #9
</font><font color="blue" class="small">( I stopped using the slime stuff. When you change a tire or have to pull a tire you will understand why. )</font>
Are you referring to Slime or Fix-a-Flat?
I have never heard anyone complain about tire changes with the Slime installed.
I too would vote for Slime. It's in all my off-road tires and I no longer get leaks nor flats.
   / slow leak in tire rim seal #10
2021 CATERPILLAR 279D3 SKID STEER (A51242)
2021 CATERPILLAR...
2006 Pearson Quantum Fire Truck (A50323)
2006 Pearson...
Caterpillar D7G Bulldozer (A50514)
Caterpillar D7G...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
UNUSED RAYTREE QUICK ATTACH VIBRATING BUCKET (A51244)
UNUSED RAYTREE...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
