Boiler74
I would like to seek the wisdom of the forum on a problem I had tonight. I was given a small wood burning stove by a family friend. They bought it during the 70's energy crisis and never installed it. It says "Fire Horse" on the door underneath three screw down dampers. Sat in their garage for years. Then I get it. When I built my house I put a flu into the basement for a backup wood burner. Finally installed this wood stove before winter as a backup. I don't need to use it much as I have geothermal heat. But I wanted to fire it up just as a test. So I did that tonight and filled my house with smoke. When I installed it, I used high heat caulk at all joints to help seal. But I still got smoke.
I did notice some of the smoke came from the outside case of the burner itself. As it was the first time this had been used after sitting so long, I figured that was the cause. Just burning off crud from all those years. So I waited until that stopped, aired the house out, and kept burning. More smoke followed.
Possible causes
1. My house if very tight. Could the stove not be drafting well? I did try cracking a window, but couldn't tell if that helped.
2. I ran the HVAC fan to draw the heat into the rest of the house. Could that pull smoke out of the stove?
3. Did I have the three screw down dampers closed too much, or open too much. Tried both ways.
4. Did I not seal the joints of the flu pipe enough. The pipe is simply a 90 out of the back, about 4 feet of pipe, and another 90 into the thimble. Concrete all around.
Those are just my thoughts. Any others greatly appreciated. I would like to get this figured out before I have to use this for real in a power outage or worse.
Any help appreciated.
Josh
Possible causes
Josh
