Smokin' John Deere
   / Smokin' John Deere #1
catfishhunter
Michigan
John Deere 2020
Smokin\' John Deere
I have a John Deere 2020 that blows blue smoke pretty bad. Its using oil. I think I have a stuck ring or bad valve seal. I'm somewhat knoleageable about engines, but don't want to get too deep into a repair myself. I have it at a hobby farm in Missouri so it sits a bit. Does anyone have some ideas on some easy things I can try or test before I take it in? Thanks!
   / Smokin' John Deere #2
Re: Smokin\' John Deere
Just for giggles I would throw some top end lube to it good and heavy. Maybe some of the ol MARVELOUS MYSTERY OIL."spellin" /forums/images/graemlins/blush.gif Unless its got a sack full of hrs. on it and its time for an overhaul anyway. Dang sure cant hurt ta give it a try, I know the stuff works on rings and valves. Im sure a few will agree and many will disagree. Good kuck eather way hand /forums/images/graemlins/cool.gif
   / Smokin' John Deere #3
It is diesel isn't it?
Sometimes just occasional use and start up and stop without getting up to operating temperature will foul things up so they do some smokin'.
Drop it off at a dealer and have it checked out. If diesel, there may be an injector plugging up, and if gas, they could check out the compression to give you some idea where you stand for the near and far future.
Good luck.
Its gas actually. Thanks for the tip on the compression test. I'm going back next month and will give that a try.
Thanks for the tip on the mystery oil. A friend of mine recommended that too and I bought some to use. I guess I can put some in the crankcase and a teaspoon in each cylinder. Is that what you would recommend? What other type of "top engine lube" would you recommend?
   / Smokin' John Deere #6
I tried the Mystery oil in two of my tractors. They were both smokin' pretty bad. After that got into the engine (about 3 minutes) things REALLY started hammerin'!!! Shut it down quick. Started it up again and it rattled worse. I drained the oil, put in a new filter and started it back up. It continued to hammer....So I figured that stuff must've gummed something up pretty bad. Sounds like maybe sticky lifters. Sooo I shut it off and grabbed a can of PB Blaster. I squirted that in the oil filler tube and counted to ten. Started it back up and the knock dissappeared, annd the dang thing runs stronger! There's even less smoke now! So I figured, what's good for one tractor is good for the other. Now they BOTH run great!
I don't recommend this. Just sayin' what happened in my experience...
   / Smokin' John Deere #7
Outside of diesel fuel M.M.Oil is all I have used myself. Alot of old timers swear by M.M.O. On the compression check, do a wet and dry test. You can get a cheepo comp. tester bout anywhere and do it yourself .
   / Smokin' John Deere #8
For a gasoline engine only, not diesel, get an engine cleaner meant to pour through the carburetor. Follow the instructions on the can, which generally is run engine at a fast idle and pour it in the carburetor at a slow rate. Make sure you are outside, this will lay down a smoke screen. I've used this on a car engine and it cleaned it up pretty good.
On a diesel, this will act as a fuel and you'll get a run away engine. That is it will accelerate in engine speed--run up way past the "red line" of the engine. Cutting off the ignition won't stop the engine either. Only covering the intake, to cut off the air, will stop the engine.
   / Smokin' John Deere #9
For **GAS** engines, some auto trans. fluid will clean up any carbon in there pronto. This too will smoke like a chimney. Add a little through the carb and be ready to throttle up as it will stumble.
Use at your own risk, but it's worked for me and a couple friends.
   / Smokin' John Deere #10
Many seasons ago a friend gave his car, a '61 Ford 390, over to a mechanic to take care of some engine problems. The guy poured water and dried rice in the carb. Kept the engine running/stumbling while doing this. Afterwards, it ran like new! The only thing I could ever bring myself to do was the water trick. That does work well, it just doesn't last very long. On my older cars I used to always run one qt of Rislone in with the regular oil. Alays had great success with that. I wonder just how many ways are there to 'reclaim' an engine? Dried rice? Anything from Stouffer's frozen section? Something from McDonalds?? /forums/images/graemlins/grin.gif
2022 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A53843)
2022 ALLIANCE...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A54814)
2012 Freightliner...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
