Snapper Comet Clutch
   / Snapper Comet Clutch #1
RSKY
Veteran Member
Kentucky, West of the Lakes, South of Possum Trot.
Kioti CK20S
I need to lower the drive plate on a Snapper Comet lawnmower. This is the plate attacher to the motor shaft that the rubber edged drive 'clutch' acts against. It is rusted on and I am afraid too much force will damage it.
Any suggestions?
   / Snapper Comet Clutch #2
Usually, the rubber drive disk needs replacing. I'm not sure how to get it apart other than it is a keyed shaft usually. Some have a retaining screw.
   / Snapper Comet Clutch #3
the one I had needed to be machined (it had ripples worn in it). It is held on a keyed shaft with two set screws (both in the same hole). Remove the first and then look for a second one.
   / Snapper Comet Clutch #4
The rubber drive disc is held on with 3 some 4 bolts my snapper comet is 3, it takes a 7/16 0r 1/2 inch wrench it's not to hard I have replaced several. The cantelever metal disc it engages against is held on with 2 Allen head screws and has a shear pin it slides onto. You will have to remove the rubber drive disc if you have to replace it either way. I have worked on snapers older ones for 35 years. I will be glad to hel you in anyway I can.JAMESMATTDILLON
WB Mower (A50120)
WB Mower (A50120)
FRONTIER AV50H LOT NUMBER 114 (A53084)
FRONTIER AV50H LOT...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2022 Heli Forklift (A51573)
2022 Heli Forklift...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
