Snapper HI-Vac walk behind 21 inch mower suction
   / Snapper HI-Vac walk behind 21 inch mower suction #1
jorddavi
Burlington, NC
Ford Golden Jubilee
Does anyone know if there has been a significant design change in the housing of the walk behind 21 inch Snapper Hi-Vac decks? My two new mowers do not vacuum nearly as well as my 20 year old re-engined unit. Both the new mowers have the "rolled under" vacuuming deck lip, not the "rolled out" mulching deck lip. I have installed a high lift blade with wings, but this has not helped much. For mowers costing $850-$1200 (Kawasaki and Honda engines), I would expect better performance.
Any thoughts?
   / Snapper HI-Vac walk behind 21 inch mower suction #2
Any thoughts?
You might want to check engine RPM. I would think that affects vacuum as much as anything else. Many newer engines have had the speed lowered. I believe the safety rules now specify a max blade tip speed and the larger the deck, the slower the engine RPMs. I think a 21 inch deck is supposed to be 3250 RPM.
2023 Yamaha Wave Runner Deluxe with S/A Aluminum Trailer (A51694)
2023 Yamaha Wave...
Heavy Duty Jumper Cables (A51694)
Heavy Duty Jumper...
2020 Kubota MX5400 (A50123)
2020 Kubota MX5400...
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
