Snow blower- Adapting a skid steer mount
   / Snow blower- Adapting a skid steer mount #1
gates
Maryland
JD 6410 Cab MFWD & FEL,JD 4610 MFWD & FEL,JD 4720 Cab MFWD & 400CX FEL ,Kub. RTV 900W,Hon. Rincon w/plow,Yam. Grizzly,Case 1845C,580L,580SE,Terex 636,Grasshopper 428D,Takeuchi TL 150,Brush Bandit 150
Has anyone adapted a hydraulically driven skid steer snow blower to there tractor. I am considering using the power beyond port for the supply, then thru a valve, and out to connectors on the loader arm. The mount would consist of a skid steer adapter mount for the loader arms. I think this can be done for half the amount of a front mounted PTO driven blower. Constructive criticism, or for that matter, any criticism
is welcome. Just be gentle, I'm fragile! /forums/images/graemlins/cool.gif
Ron
   / Snow blower- Adapting a skid steer mount #2
Skidsteers run their attachments at 15-30 gpm (or very roughly 15-30 hp @ 2000 psi). If one of your tractors can produce a similiar flow/pressure it would work, but most tractors discussed on this board won't match a skidsteer's hydraulic output (at least they won't without having a separate PTO driven hydraulic pump.)
Tractor produces 17gpm @ 2500psi. The skid steer mount snow blowers are purchased ala-carte. You have to spec out the pump size, anywhere from 11gpm-35gpm. I am waiting for a response back from JD in regards to the application. I have concerns about heat build up and the snow blower using to much flow and starving the hydraulics.
Thanks for the response
Ron
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
ABO TANK (A50854)
ABO TANK (A50854)
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2008 International 4400 (A50323)
2008 International...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A51222)
2020 CHEVROLET...
