Snow Equipment Owning/Operating Snow Blowing
   / Snow Blowing #1
old_doc
JD 4310 e-hydro
I am considering a 32hp tractor such as the JD 4310. Is this enough power for the five and a half foot dual stage blowers out there? Thanks.
Doc
   / Snow Blowing #2
It depends on the type of snow you are dealing with but that should be enough HP. My tractor is 24HP and it handles my 5 foot two-stage snowblower except in heavy downfalls (more than a foot) of very wet snow. In general, my experience is that it takes about 5 to 6 HP per foot of snowblower to do a good job.
   / Snow Blowing #3
Doc
I had a 32HP Ford 1910 with a 66" snowblower. It worked well. If you have heavy wet snow you may have to adjust your speed. I had turf tires and ag tires. The turf tires were wider than the snowblower. In the winter time I switched the turfs out for the ags, set on narrow.
RonL
   / Snow Blowing #4
I'm running a 78" blower on 30 PTO hp without a problem. 3inches or 3feet, the AgroTrend does a fantastic job.
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A60460)
2020 Ford F-250...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
