Snowthrower: need a second rear oil outfit for hydraulic controls?
   / Snowthrower: need a second rear oil outfit for hydraulic controls? #1
Fredartic
Hi,
I just received my new tractor (Bobcat ct-122). I asked for a second rear oil outfit for using a snowthrower... I don't know how it works; I'm newbie user. One Massey dealer gave me a price for a tractor with two rear oil outfit, cause he said that I will need it for the snowthrower... Why? The point is that my Bobcat dealer doesn't install a second rear oil outfit and he told me that I don't need it... depending on what kind of snowthrower I will have... Someone can explain me clearly what does it mean? Thanks
If I don't need a second rear oil outfit, I will ask him to give me something of the same price...
   / Snowthrower: need a second rear oil outfit for hydraulic controls? #2
A set of hydraulic remotes at the rear will allow you to use a hydraulic chute rotator. Having two sets of rear remotes would allow you to rotate AND adjust the chute deflector.......... this allows you to place the snow wherever you want. Most basic rear blowers have a manual crank to rotate the chute...... and changing the angle of deflection will require you to get off of the tractor and adjust it manually. All in how easy and convenient you want your operation.
   / Snowthrower: need a second rear oil outfit for hydraulic controls? #3
you could also use a splitter with the one valve.
   / Snowthrower: need a second rear oil outfit for hydraulic controls? #4
Many snow throwers don't use any remote hydraulics.
Some use an electric motor to turn the spout, most the hand crank.
Going to depend on what type of blower you get, how many fancy gadgets it has on it.
There are electric operated splitters that will take your one set of hyd ports and allow you to push a button to chose which cylinder will get the hyd flow.
--->Paul
FAKE (A52472)
FAKE (A52472)
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
Informational Lot - Shipping (A52748)
Informational Lot...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
