So... Yanmar Ex450 vs. Kioto DH45SE vs. Kubota L4600
   / So... Yanmar Ex450 vs. Kioto DH45SE vs. Kubota L4600 #21
I own the LX4900, fantastic machine. I would get a hoe for it, but already have one on my smaller compact. Any questions on the LX series, ask away....
   / So... Yanmar Ex450 vs. Kioto DH45SE vs. Kubota L4600 #22
The Yanmar's are nice ... I don't like that they're 400-500 lbs lighter than the others, and they seem to lose more PTO HP thru driveline loss than the others. Could be from their smaller displacement engines?
please look at my new post -- Yanamar 4900 with backho will be coming in at about 32500 -33000. What do you think?
   / So... Yanmar Ex450 vs. Kioto DH45SE vs. Kubota L4600 #24
With a backhoe, I'd be looking for the heaviest tractor with the highest hydraulic flow. Then I'd load the tires for even more weight. When digging, no substitute for weight to let you put the power to the ground. Hydraulic flow is important for implement speed. Backhoes use a lot a fluid and you want fast response, especially when you start using dual functions simultaneously. Hoe is most convenient off of rear hydraulic remote ports. And you can use the port(s) for other things, like top-n-tilt.
   / So... Yanmar Ex450 vs. Kioto DH45SE vs. Kubota L4600 #25
+1:thumbsup: On the Kioti DK-45 you can do the hoe return line directly into the fill port reservoir with an available kit from any dealer, which allows for more flow with less restriction and cooler fluid temps!
BTW, I have a hydraulic thumb from MIE, which is on the machine, but not yet hooked up to my hydraulic lines ~ waiting on above arctic temps to start using it.
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
SKYJACK SJIII 3226 ELECTRIC SCISSOR LIFT (A52705)
SKYJACK SJIII 3226...
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
Pair of New 700/40-225 Alliance Tires with Rims (A55301)
Pair of New...
2016 Ford F-450 4x4 Ambulance, VIN # 1FDUF4HT3GEC45874 (A54865)
2016 Ford F-450...
