Sod sob story
   / Sod sob story #1
Pilot
Veteran Member
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
Part of lawn was rutted from repeated mowing in same pattern and moles mounds & I decided to redo the area. Couple guys who should know (farm supply owner & farmer) suggested using Roundup, wait 2 weeks & till. I sprayed, waited about 4 weeks. Ground is very dry and to insure the tiller would penetrate, I cultivated before tilling. That may have been a mistake.
Made a pass with the tiller this morning and all it seemed to do was stir things up. Still have big lumps of sod; it seemed like the tiller just moved the lumps around.
Any suggestions on how to break up the sod?
Should I go slower, first gear low range? Plan on a dozen passes or more? Wet the area down, then till?
   / Sod sob story #2
Go slower and tilt the tiller forward with the top link.
   / Sod sob story #3
Make sure the flap on the tiller is closed, and go slow. It may take several passes. Another thought, if you have a drag, go over it several times with that. I had to do that to get my food plot broken up.
Will
   / Sod sob story
Well, apparently I cried for help too soon. Tried again in first gear low range & it worked better, but still not what I had hoped for. But I found a BIG difference when worked an area that got watered when I watered the lawn. One pass was as good or better than 5 or 6 passes on the dry ground.
I'll tilt the tiller forward as Fawken suggested. Will_C, the flap is closed. I don't have a drag.
I've got the sprinklers going now!
   / Sod sob story #5
You are talking about a rotor tiller, and not a field cultivator, correct? I can make two passes with my KK and it would be ready to plant.
   / Sod sob story #6
If you get this situation again, and it is not too big of an area of the lawn, it is best to remove the sod first if you want as smooth a lawn as possible. Depending on the type of grass killed, it will still clump up during tilling and not be a perfectly smooth seedbed. If the dead grass is mostly decayed, it may smooth out, but many times it will not. Good luck.
2014 FRAC TANK (A53843)
2014 FRAC TANK...
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2014 FORD FOCUS(INOPERABLE) (A53843)
2014 FORD...
LINDE WELDER (A53843)
2012 EAGER BEAVER 55GSL/3 RGN TRAILER (A53843)
2012 EAGER BEAVER...
