Solar Panel Controller Needed
   / Solar Panel Controller Needed #2
Is that a 22 watt 15 volt panel? If so any controller over 2-3 amps should be ok. But not all controllers are the same. What are you planning to power with the panel?
I'll check the wattage. If feasible I'll be using it to keep my tractor battery charged instead of the battery tender.
   / Solar Panel Controller Needed #4
I've been using 2 different 10w panels to keep batteries charged - one I bought off of Amazon and one I scavenged from an old solar electric fence charger I had for years. I had to purchase 2 charge controllers from Amazon to use these panels and so far all has worked well for several years now. I have 1 panel & controller on my garden fencing with a deep cycle battery and it has worked very well for about 4 years now. The second one I have in a window in my shed and use it to keep my mower & boat batteries charged thru the winter inside for about 6 years now. Both charge controllers were inexpensive - maybe $10 each. Can't remember what I paid for the one 10w panel I bought off Amazon but it wasn't over $20. These 2 controllers say you MUST have a battery attached BEFORE you attach the charge wires from the panel, I just put a disconnect in and make sure the battery leads are attached FIRST like the directions say. They say it will fry the controller if you don't do it this way and I don't want to test this on mine … Anyway, the 10w panels are plenty for keeping batteries up to charge.
   / Solar Panel Controller Needed #5
Dont use that CC. There complete junk and can damage the battery your trying to save. Your really better off not putting anything on vs useing that CC.
The panel is 23.3 watts.
   / Solar Panel Controller Needed #7
I always like products that have the company name on the product. Amazon.com : Victron BlueSolar PWM-Light 12/24V-10A Solar Regulator Controller : Patio, Lawn & Garden
Victron is a good company. These are both PWM controllers. MPPT controllers are much more efficient. Might want to check out the difference. BUT a MPPT will cost about $100 more. Where ever you mount the controller, it will need to be kept dry. Renogy also is a good solar company. This one is waterproof (so it says). https://www.amazon.com/Renogy-New-V.../B07YXZMKD2/ref=psdc_2236627011_t3_B01BF5C66Y
Can you recommend an inexpensive model?
   / Solar Panel Controller Needed #9
Do a bit more research. Check the panel output voltage. From my limited surfing it appears she Sunsei SE series are various capacities of battery chargers. As such it may (or will) have the regulator built in. You may need no additional regulation with that model.
   / Solar Panel Controller Needed #10
It is listed on Amazon as Unavailable but does give info. I was thinking of it as a solar panel. It is sold as a battery charger. But also, in the description it recommends a solar charger or regulator to prevent overcharging. You should be able to find all different prices (usually based on type and current capacity). Again, look on Amazon for the major brands. I use Victron, but they can be expensive and not necessary for your needs. But they do have one or two lower cost. Renogy is a major brand in solar also. I use the solar to charge and maintain my trailer backup battery, trailer GPS. If you are leaving your tractor outside, you may someday want to include a GPS tracker on it. The solar will maintain that also. Most solar controller should have 2 connections for each of these - Solar panel (voltage input), battery (Battery charging output), and load (output to operate additional device) - Load could be gps, light or other. Renogy has this one, but I am not familiar with it. https://www.amazon.com/Renogy-Wanderer-Amp-12V-24V/dp/B07NPDWZJ7/ref=sr_1_3?crid=ZKJZ09WPVU0F&dchild=1&keywords=solar+controller&qid=1635529795&s=lawn-garden&sprefix=solar+controller,lawngarden,91&sr=1-3&th=1
Also, be sure it is compatible with the type of battery you want to charge.
Delta Consolidated Fuel Tank 48000 (A51039)
Delta Consolidated...
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2011 TROXELL...
2016 VOLVO VN SERIES SLEEPER (A50854)
2016 VOLVO VN...
