Solved- Tip Tractor Hydraulic does nothing post drain/fill
   / Solved- Tip Tractor Hydraulic does nothing post drain/fill #1
countryguy1225
Fenton, Mi
Kubota M6060 & L2550GST(4wd), W/ Backhoe attch. Mitsubhish MT160D (4wd) :- )
I simply wanted to put this one out in the 'ether' as I did some searching and found some leads... But not my particular fix.
It may even sound weird, but it solved my problem.
- Drained and filled per Mfr. Manual (or so I thought).
- power up, run 5-10 mins. No Hydra's Nada on bucket or 3pt
-Search & Search google. Leads about suction leak and need to run longer.
-Run another 15mins. Nothing.
- Review manual- Hmmmm Step 13. Wicked step 13.
-Fill the new hydraulics filters with oil before putting them in.
- I simply unscrewed, filled, and off I went.
Whew! Panic city. Love my Kubota 2550gst. happy camper all around.
Another lead I had was when I changed the fuel filter on my Mitsubishi 4wd. I did not know that I had to fill the
bowl there either. Loosened to let air escape, turned on fuel petcock, filled to running over. carefully screw re-assble.
Experience is a tough teacher. Test first and those lessons of then settle right in. Being a 45 year city & suberb guy who bought a 10acre place, grows hay (350 bales this first year) and married a TSC gal. doing just fine. :-0 hehe.
keys
Hydraulic fuild change not working does nothing
   / Solved- Tip Tractor Hydraulic does nothing post drain/fill #2
Ya.. I even fill my car's oil filter the best I can before putting it on..
great idea. even if to moisten the paper and prep for faster startup cycle w/ these complex engines. Sold! I will be doing that too.
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2017 Nissan Rogue SUV (A50324)
2017 Nissan Rogue...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
