Something to watch for...
   / Something to watch for... #1
bgott
Veteran Member
Houston, TX.
2001 TN65, 1951 8N Ford
...when changing quick release loader implements. I was installing the pallets forks yesterday when I had a booboo. I approach the implements with the loader arms in near full dump postion. I do it this way so when I first lift the implement I can easily see if I have both sides of the quick attach mechanism hooked before I roll the thing back and get off and set the locks. I found out the hard way that the lock levers can very easily hook into the backstop on the fork assembly and bend when you tilt the forks back. The levers will bend far enough to necessitate using a long pipe to bend them back to a useable position. This is on a NH TN 65, you might not run into this problem on others.
Kubota HB74 Hydraulic 74in Hopper Broom Sweeper Skid Steer Attachment (A46683)
Kubota HB74...
2025 REDEDLIFT CPD25-XD4 FORKLIFT (A45678)
2025 REDEDLIFT...
2019 Mitsubishi Mirage Hatchback (A46684)
2019 Mitsubishi...
2007 GMC Sierra 1500 Ext. Cab Pickup Truck (A46684)
2007 GMC Sierra...
Ezgo Electric Golf Cart (A47307)
Ezgo Electric Golf...
1999 Ford F-350 Lariat (A47307)
1999 Ford F-350...
