source for 2000 RPM to 540 RPM gear reducer?
   / source for 2000 RPM to 540 RPM gear reducer? #1
FredWalter
Bronze Member
Southwestern Ontario, Canada
John Deere 5300, Gravely 8163G, BCS735, etc
I recently saw a front mount 3 point hitch on a compact tractor.
The front PTO (at 540 RPM) was driven by the mid PTO (at 2000 RPM)
through a gear reducer.
Anyone know where can you buy this type of gear reducer,
and how much one will cost?
   / source for 2000 RPM to 540 RPM gear reducer? #2
540 stepping up 3600 are most common.. lotsa gensets use those
Guess you might find a genstet that uses an 1800 rpm engine.. and grab that gear box and make it work.
i believe I've also seen a thread here where a guy built a pulley reducer for his tractor's mid pto to drive 540 rpm implements.. etc.
soundguy
   / source for 2000 RPM to 540 RPM gear reducer? #3
MTD sold this model #954 Maybe you can make one like it if you are handy. In comming 2000 RPM to a 8 tooth sprocket -chain to a 15 tooth on the same shaft an 8 tooth -chain to a 16 tooth giving you 540 RPM.
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2018 KUBOTA SVL95-2S SKID STEER (A51242)
2018 KUBOTA...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52128)
NEW 2024 LOAD...
Unused Delta Crash...
2012 Nissan Rogue SUV (A50324)
2012 Nissan Rogue...
