spray outfit with booms
   / spray outfit with booms #1
accordionman
wright city, mo.
KUBOTA L3000DT, FEL.
HELLO TO ALL,
has anybody made their own spray outfit with booms?
if so what size pump, engine, and tank did you use?
did you make it from plans, or just put something together?
comments appreciated.
accordionman
wlbrown
   / spray outfit with booms #3
I built my own a couple of years ago.Used a plastic 30 gal soap tank that I got from the local car wash,an rv pump,3/4 pvc pipe and fittings,rubber hose,and some spray nozzles "borrowed" from work,.I sprayed with a 10' sect.out both sides,then came to the conclusion that i could get by with shorter booms and raise the 3pt higher.Shorter booms allow me to just drive the tractor without worry about catching on something.Happy buiding.
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
John Deere 7810 Tractor W/Loader (RIDE AND DRIVE) (A50774)
John Deere 7810...
2015 CATERPILLAR 336FL EXCAVATOR (A51242)
2015 CATERPILLAR...
(4) 10' High Pole Swinging Gates (A50515)
(4) 10' High Pole...
2000 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A51242)
2000 BOMAG...
Terex Concrete Trowel (A47384)
Terex Concrete...
