Spreader for for wood ash/composted manure?
   / Spreader for for wood ash/composted manure? #1
wardo78
Putney, VT
JD 5100M, JD 4520, Mahindra Max 28xl
Hello All,
I own a JD 5100M, and am looking to buy a used material spreader for wood ash and composted manure. My property is 85 acres of open hilly Vermont land, that has been fallow for 7 years. I've looked at a variety of options, but would love to get first hand input on what works? Is a litter spreader going to do the job? If not, what am I looking for?
Thanks,
Wardo
   / Spreader for for wood ash/composted manure? #2
I have a Gehl 315. I pull it with a old bigger Zetor.
It works well for both. it is a bit heavy about 5000# unloaded.
Im not sure how heavy a 5100 M is. But you need about 12,000# at least and decent traction to handle the spreader weight loaded.
Thanks for the response. The 5100M with loader probably weighs 10,000 pounds. I was wondering how a side discharge manure spreader would work with the wood ash. What sort of coverage are you getting? Are there any issues with clogging or uneven spreading?
Regards,
Ward
   / Spreader for for wood ash/composted manure? #4
Side discharge gehl with the slinger hammers/flails works well to break up the ash curds. I used a lime spreader and it was not ideal, plugged up, left big chunks and my ash had already been run through a crusher.
What sort of a spread pattern are you getting?
Thanks,
Ward
   / Spreader for for wood ash/composted manure? #6
good pattern 20 to 40 ft unloades 6 ton or so in a couple minutes.
load it up run 6 of 8 gears at 75% throttle
   / Spreader for for wood ash/composted manure? #7
Anyone use a rear discharge spreader on ash? I've heard they will work ok but I suspect a side discharge would be better. I will find out how my old NH479 does this fall anyway.
   / Spreader for for wood ash/composted manure? #8
I use an old Dearborn manure spreader on my place. I've pulled it behind my Kubota M6800, my Polaris Ranger 500, and most recently behind my Toyota FJ Cruiser. When it's fully loaded its a little heavy for the Polaris, though. It works well. I load it with manure ( horse, cow, llama) and then top dress it with a few inches of woodash from my outdoor furnace. I get a span of about 20 feet. Works just fine for me.
   / Spreader for for wood ash/composted manure? #9
I think you'd need something with the rear gate, our rear discharge would apply it at way too high of rate for 1:1 lime value woodash. Low quality ash with 3:1 ratio would maybe be ok?
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
LMC LOT NUMBER 142 (A53084)
LMC LOT NUMBER 142...
EZ-GO Textron Electric Golf Cart (A51694)
EZ-GO Textron...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
UNKNOWN 16 T/A TRASH TRAILER (A52472)
UNKNOWN 16 T/A...
