square baler knotter problems
   / square baler knotter problems #1
Pusto
Lavaca County, Texas
New Holland 3930
I have a New Holland square baler 275, which is about forty years old or so.
I am having problems with the knotter, specifically, the knotter leaves short pieces of baling twine on top of the bales of hay, one for each twine. It will bale a few bales ok, with the little pieces of twine, but then it will foul the knotter and I have to stop to clear it. Any ideas?
   / square baler knotter problems #2
Sounds like the twine cutters are dull. They should cut as the knot is pulled from the bill. If youre using plastic twine, a switch to sisal should improve it. Sharpening the cutters should be easy as well.
larry
Thanks, SPYDERLK, for your quick response. I will attempt to sharpen the twine cutters, which sounds like a good solution to the problem, since the general appearance of the knots on the bales is ragged. I am using sisal twine, 9000. I have owned this baler for about a month, and it seems to be in really good shape...barn kept, one owner, etc. I am baling grass that usually is four or five feet tall this time of year, but now I am ending up with stemmy winter grass and old thatch.We are in drought conditions here in South Texas, and more is on the way. I think that the density and weight of the bales must vary according to the condition of the hay being baled. The farmer who owned the baler before me must have liked seventy pound bales, since he had the screws down tight. What about the relationship between the twine holder tension spring and the density of the bales? Does that have any bearing? Thanks for your help.
   / square baler knotter problems #4
If the twine cutter blades are rivetted onto the wiper arms, grind them off and replace with bolts and prevailing torque nuts. You may have to pull the arms out of the knotter frame to do this, but its worth the time. Check the wiper arm balls to make sure they freely rotate while you are at it.
Twine holder tension may be the cause of your problem. If it's too tight, the twine is weakened by the fitment. It would be tighter if there had been plastic twine used previously. Your manual should give you specs for twine box and twine holder pull out tension adjustments for both types of twine.
Bale density is regulated by feed rate, hay resistor condition and clamping force settings on the bale case cranks. All the twine holder does is conatin the knot ends until the billhook completes the knot.
   / square baler knotter problems #5
I agree that sharp twine knives would probably cure your problem. But be aware that a 1.5" or so length of twine is ALWAYS the product of a functional Deering-style knotter. The bits of twine in and of themselves are completely normal. They should flow through the knotter and ride out of the bale chamber on the bale, next to the knot.
You say the short pieces of twine left after each knot is tied is normal. I have had some of these little pieces get stuck in the twine disc, where it apparently produced a fouled knotter with a long (48" or so) piece of twine hanging off of it. The bale produced only had one twine, with the other piece of twine fouled in the twine disc and bill hook. I think my problem might be a combination of factors, such as bales too light, twine holder tension spring too tight, and who knows what? The material I have been baling is very dry and perhaps the bales are too loose. Thanks in advance.
   / square baler knotter problems #7
new holland square baler will not make a full revolution without breaking the shear pin for some reasoonthe knotter bar is not staying back all the way and its stopping the packer ram from making the necessary revolution. any body had this problem and know how the fix it ?
   / square baler knotter problems #8
Choose Items
You have a knotter timing or needle latch adjustment problem, most likely. Follow the link and buy/download an operator's manual for your baler so you can troubleshoot & repair it yourself. A manual will be the best money you spend on your baler since you purchased the machine.
   / square baler knotter problems #9
That darned needle basket brake can also cause problems. I've been on both side of the brake adjustment. Too loose and the cage drops down putting the main blocking lug into play and too tight the shear pin pops. I've had all the above symptoms on the knotters and still trying to sort out the issues. My next effort is to pull the plunger and replace bearings and get the hay knifes adjusted. That is this winter project. Oh yeah My machine is a very worn NH 269 that was really heading for the scrape pile and I tried to resurrect. bjr
   / square baler knotter problems #10
Having the knotter 'home' position properly set alleviates 99% of the knotter brake problems. When 'home' is correct, extra brake pressure isn't necessary.
   / square baler knotter problems #11
I have a New Holland hayliner 273 Problem with twine breaking after it ties the knot behind the knotter.
   / square baler knotter problems #12
I believe there are 2 types of twine one is for square bales, some round baler twine won't work. We had same problem
   / square baler knotter problems #13
Hey, hope you get a good reply to your question, I have same issue, and now hay season is upon us again.! tks, JS
   / square baler knotter problems #14
Bales to tight ? With startup loosen adj on side of bales and after a few bales retighten again
   / square baler knotter problems #15
Well, Tonite will be the inaugural starting of the NH 269 since the plunger rebuild. I've been rereading all about the timing and knotter trip lever settings. I'll have reset all the settings. Hopefully I'll get some bales made this year. I'll report back. bjr
   / square baler knotter problems #16
Were using a NH 500 and only the center twine brakes loose after about 100 bales we've replaced
the cutter and twister and several other parts but it still brakes the twine,any thoughts.
   / square baler knotter problems #17
Quality of twine? What brand are you using? I use Bridon 9600 in my Hesston. Tried Tighton and others and they broak just as you described. It also may be you tension disks are to tight, or look for a bur on the wiper arm.
Also if the roll was exposed to sunlight for too long, it can be weaker on the side exposed to the sun.
   / square baler knotter problems #18
You got it,it was the wiper arm it was worn out and very loose works great now thanks
2022 Horizon (A55973)
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
iDrive TDS-2010H...
2013 CATERPILLAR 950K WHEEL LOADER (A60429)
2013 CATERPILLAR...
