Squeaking noise on a New Holland TC29D
   / Squeaking noise on a New Holland TC29D #1
PDobson
New Holland Boomer TC29D
Hi, I have a 2006 TC29D, it has developed a squeaking noise when running at minimum 2000 rpm and higher ground speed in both 2 and 4 wheel drive. In lower gears and slower ground speed, no noise. Thanks in advance for any suggestions, I have greased the front axle and have checked the fluid levels in the front axle and each front hub.
I tried to attach a video but not able to, any suggestions on that would be great too, thanks.
   / Squeaking noise on a New Holland TC29D #2
Welcome to TBN.
A video would be helpful.
Is the squeak coming from a specific area?
Thanks, sounds like coming from the front of the tractor. Can't tell for sure if from the engine or front end.
Didn't think it was engine related as is only make the noise when moving.
I have tried multiple times to attach the video and also paste it in, get a message that the image file type is invalid file. Any help on this would be great, thanks.
   / Squeaking noise on a New Holland TC29D #4
Sounds like it is probably the 4WD driveshaft rubbing on the shield.
Thank you both for the replies, you will excuse my lack of knowledge on this. Where would I check for it rubbing on the shield? Not finding any videos or diagrams to assist with the location, thanks.
I think I was able to get the video to load of the noise, thanks.
   / Squeaking noise on a New Holland TC29D #8
Have you greased the zerk on driveshaft between transmission and front axle?
   / Squeaking noise on a New Holland TC29D #9
Strange "squeak". Sounds more like a plastic squeak, but can't define. Does it occur the same way every time as in the video? Could jack up all four tires off of the ground and try again.
In either 2 or 4wd, the driveshaft turns in the cover from the dropbox at mid-tractor
Thanks, thought I did, will get back under it and check.
2020 Kubota B2601 Loader Ready 4wd Tractor (A46877)
2020 Kubota B2601...
Cummins Turbo Diesel Engine with Transmission (A44571)
Cummins Turbo...
2020 Toro 75742 40in Zero Turn Mower (A44572)
2020 Toro 75742...
2025 Wolverine DB-15-84W Skid Steer Dozer Blade (A47484)
2025 Wolverine...
2019 Ditch Witch HX75 HYDRO VACUUM (A47484)
2019 Ditch Witch...
2018 Isuzu NRR 18ft Box Truck (A44571)
2018 Isuzu NRR...
