Squeaky PTO
   / Squeaky PTO #1
gocards1177
Rolla, MO
Did about 6 hours of cutting with my MX10 on Saturday morning. Before I started I adjusted the slip clutch per the manual and greased every zerk I could find. Toward the end I noticed an intermittent, high pitched squeak. It probably happened 25% of the time. It's hard to tell with all the noise but based on the rhythm of it it sounded like it was coming from the pto shaft, specifically where the driveline and slip pto shafts meet. At that spot there is a bearing bit it is a sealed bearing.
One of my co workers suggested that maybe I left the clutch too loose. Is that a possible source for a squeak? Seems like a clutch slipping would be a continuos grinding noise. Easy enough to test though - just tighten the 6 bolts. Is there a way to test the bearing short of replacement?
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
1968 CHEVROLET C10 1/2 TON PICKUP TRUCK (A51222)
1968 CHEVROLET C10...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
