st1300d or beaver
   / st1300d or beaver #1
stmechanic
Barbourville, Kentucky
st1300d
I just bought a satoh tractor , the hood has satoh beaver on it and the side of the tractor is stamped st1300d , i cannot find this combination on the internet. It appears to be two different tractors, i assume the stamped number would be correct, if so, i am needing gears for the transmission, the man i bought it from said first and reverse were out of it. Also need a rear rim and probably other parts as well once i get into this tractor, any suggestions on where to find these parts would be much appreciated, thanks Mark
   / st1300d or beaver #2
Welcome from Oklahoma.
The name Beaver was marketing name, the official model name is ST1300D, which means you have a Satoh Tractor, 13 pto hp, diesel engine, 2 wheel drive. If the model number ended in FD it would mean 4wd diesel engine.
Do a google search on Misubishi tractor parts and you should find what you need. Since only first and reverse are out I'd check for a broken shift for first.
Ken
2018 John Deere 460E Articulated Dump Truck (A55218)
2018 John Deere...
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light Tower (A52377)
2019 Allmand Bros...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
