Stable / hay storage build
   / Stable / hay storage build #1
Mike476
Veteran Member
Annapolis Valley, Nova Scotia
MF 135 Z134 Continental, MF 1660 Cab
Made it home recently for three weeks. Drove the 1600 kms (1000 miles) in one day, didn't want to spend too much time on the road. It was a busy three weeks but I can't honestly remember enjoying time with my family more. My wife and two daughters were right there with me when they weren't working, great sense of accomplishment. Proper thing though, they're the horse people I just get to play around doing this sort of thing ;o)
I'm no master carpenter by any means, had the help of a lot of friends too, particularly when it came to swinging trusses, shingling the roof etc. Wouldn't have got it done without their help.
Day 1 at home I had to move the old hay storage shed I had built, my daughter got the chance to put a couple of hours on our new MF 1660 I had delivered my first day home. With the shed moved I had to knock a couple of maples down that were right where we wanted the building. Hated doing it, we try to keep as many of the mature trees on the property that we can.
Once they were down I cut them into lengths for milling, cleared the brush and had a friend come with his hoe to pull the stumps. Once the stumps were pulled we cleaned up all the roots.
Day 2 I had three loads of sand delivered, levelled it with the tractor, compacted it and started laying block. I wanted the building to be large enough for four 10X12 stalls and storage for a years worth of hay for our 4 horses. Decided on a 28 X 40, 10 foot wall on block style construction. Pressure treated 6x6 sill on a course of inverted starter coarse shingles to keep it from touching the concrete.
The next few days were sent framing. My wife and I had milled enough full dimension 2x4 to frame with a few years prior, I used PT's 2x6 ripped to a full 4 inch width for the sill. Short walls first.
Then we got started on the long walls
Started the sheathing next.
Trusses came but were of the wrong type (didn't order them with a tail) so I had to make some quick arrangements to get the right ones made up and delivered, screwed up my schedule. I had allowed for a day or two for weather in my planning but couldn't afford much more. It took four days for them to deliver the right trusses. Thankfully they were delivered on a Friday, had the 21 trusses placed on top of the walls that morning, had them up and all but two rows of sheathing on one side finished by nightfall that same day. Was a good day
Got the roof shingled in time for 3-4 days of rain, focus shifted to making the four stalls inside. Sheathed the interior walls with 5/4 my wife and I had milled a couple of years earlier.
For the interior walls of the stalls we went with 2x6, linseed oiled and used drywall beading at edges to discourage the horses from chewing. Works well, I used it in our run-in shelter 15 years ago, still like the day I nailed it togerther.
Stable 12.jpgStable 12A.jpgStable 12B.jpgStable 12C.jpgStable 12D.jpgStable 12E.jpgStable 12F.jpgStable 13.jpg
Didn't have time to make the four stall doors so we went with the strap style gates until I get home again at Xmas.
Built the exterior doors and hung them on Friday of the third week, took Saturday off and drove back to Ontario Sunday. My wife and daughters painted it and sent me these photos, happy with how it turned out.
Stable 14A.jpgStable 14B.jpgStable 14C.jpgStable 14D.jpgStable 14E.jpgStable 14F.jpgStable 14G.jpg
Like I said at the beginning, wonderful family project, and with the help of a lot of friends we managed to pull it off. A lot of work in under three weeks for a bunch of weekend warriors. Would do it all again in a heart beat.
   / Stable / hay storage build #6
Looks like that with keep them dry and warm.. nice looking barn.. thanks for the pictures.Lou
Thanks Lou, my wife and I will enjoy staying out of the weather a little more, cold gets to you a little more as you get up in years.
   / Stable / hay storage build #8
I nominate you for Super Dad of the Month!
Nice work and great to see families working together.
I've seen barns and sheds built on that foundation style, and of course that was the only style back when.
Do you use any modern tie-downs to anchor the wood framing to the ground?
Thanks Dave.
I haven't done anything to anchor it yet, I've been looking at different optiions for how best to do it.
   / Stable / hay storage build #10
Thanks Dave.
You are welcome.
I don't know that they did any anchoring years ago, or that you need any, just wondering if you had plans.
With enough animal heat and the hay, plus some snow cover, the ground may not freeze under the blocks. But if it were to freeze, I guess it would be best to allow the whole structure to float up and down with the frost.
Looking at old rock barn foundations, it doesn't seem like they worried about frost heaving. On the other hand, those old buildings do have some ups and downs in their sills. Could be just from settling for 100+ years too.
It takes a lot of wind to move a building, more than any normal storm will produce.
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A49346)
Yale...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A49346)
2025 Kivel 48in...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
2004 Big Tex 10PI 18ft T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
