Start a Kubota X900 other than in neutral?
   / Start a Kubota X900 other than in neutral? #1
KennyR
Big Rock, IL
Kubota 2380
Is there any way to modify a Kubota RTV-X900 so it can be started while in gear while simultaneously depressing the brake? I know that is designed as a safety feature, but I previously had a Kawasaki Mule 400 which had the ability to start in neutral as well as while in gear as long as you fully depressed the brake. I liked not having to shift each time when starting and stopping so often on a number of projects while working on my acreage.
Thanks for any feedback.
   / Start a Kubota X900 other than in neutral? #2
On my older 900 I unplugged the neutral switch at the tranny and added a jumper wire to it.
Ovrszd,
Thanks for the suggestion. Just to clarify, did you add the jumper wire from the starter to the neutral switch?
   / Start a Kubota X900 other than in neutral? #4
Ovrszd,
I think I simply jumped the terminal that plugged onto the trans switch. I'll look today and let you know.
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
Ditch Witch 350Sx Tractor (A50322)
Ditch Witch 350Sx...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
Kidd 450 Straw Chopper (A50774)
Kidd 450 Straw...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
Soil Mover Scraper (A50514)
Soil Mover Scraper...
