Start Up Question
/ Start Up Question #1
OneMan
Western NC
John Deere 3032E
I bought a 6' brush cutter from TSC about two years ago. I haven't used it the last year and it has sat outside uncovered. Is there something special I should do to it before I hook it back up to the PTO and use it?
/ Start Up Question #2
If it has a slip clutch loosen the bolts ( mark where they are set and count the turns ) fire up the PTO a few times and make sure the clutch slips then tighten it to the original setting. Wouldn't hurt to change the oil in the gearbox either.
/ Start Up Question #3
I would check the oil level in the gearbox, add grease to all the zerks, and service the slip clutch, if so equipped. You may want to change the oil in the gearbox if it looks "milky."
Steve
2017 Caterpillar 259D (A64126)
2017 Caterpillar...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
12' x 76" Tilt Trailer (A66285)
12' x 76" Tilt...
2008 CM TRAILER 14' T/A ENCLOSED TRAILER (A65643)
2008 CM TRAILER...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
