Starter Repair - Starter Won't Disengage
   / Starter Repair - Starter Won't Disengage #1
Beltzington
Platinum Member
Appling, Georgia
JD 3720
Posting this to help other's with similar issue. This was on a 17HP Kawasaki engine for a LX279 JD mower. I imagine configuration is very similar for other models and a simple cleaning saved me from buying a new starter, your results may differ.
Symptom: Starter continued to run after key was released from the start position
Fix:
Remove starter from engine (this was the most difficult part)
Remove solenoid from starter
Remove protective rubber boot from solenoid plunger
Remove dirt and grease from the plunger (I used WD-40)
Plunger should easily move up and down with finger pressure
Reassemble and reinstall starter
If you have jumper cables and a 12v battery you can test the starter off the engine. My problem was obvious by visual inspection. Good Luck!
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A51039)
3-Point Hitch Root...
2012 GALLEGOS TRAILER 130BBL VAC TRAILER (A50854)
2012 GALLEGOS...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2016 LINK-BELT  235X3 SPIN ACE EXCAVATOR (A50854)
2016 LINK-BELT...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
