starter solenoid
   / starter solenoid #1
jonjamky
ford 3000
replaced the starter solenoid on ford 3000.Starts fine now but wont shut off without pulling the the negative battery cable.
   / starter solenoid #2
If it looks like this
Tuff Stuff 7629-1 Hot Start Starter Solenoid, Universal Ford{match_type}&utm_source=bing&utm_medium=cpc&utm_campaign=SMI%20-%20Shopping%20(CSE)%20(Bing)&utm_term=4577404346894511&utm_content=All%20Products%20(Feb28_2020)
the wire from the "I" terminal will go to the ignition coil. If connected to large lug it maybe powering the ignition.
After starting you should only have power on 1 large terminal
   / starter solenoid #3
if you wired it correctly as above... its defective.
Unused Delta Crash...
2012 BIG TEX PIPE TRAILER (A50854)
2012 BIG TEX PIPE...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
CAT 312C (A50854)
CAT 312C (A50854)
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
