Starting Husqvarna 445
   / Starting Husqvarna 445 #1
hosspuller
Veteran Member
Piedmont Triad, NC
Didn't intend to have a Deere fleet - it just happened 310C, F915,102, 5200 & 5065E
I've a new Husqvarna 445. If the decompression button is pushed in, it's impossible to start. Left out, a 1/2 dozen primer bulb cycles & the choke, and it starts.
Is this normal? Or is this a problem that Husqvarna should fix?
   / Starting Husqvarna 445 #2
Husky's from cold should start in 2-3 pulls at most after 1 maybe 2 pushes on the primer choke - get the dealer to fix yours under warranty
   / Starting Husqvarna 445 #3
It is common for some saws to not start with the decomp pushed in. As your saw brakes in (ring seats, builds more comp) it'll likely start starting with the decomp. But as small as the saw is I just would not use the decomp button...
   / Starting Husqvarna 445 #4
I have a 455. I noticed the power increased after 25+ hours - break-in period I guess. From day one have had no problems starting. In our cold weather I decomp, prime maybe 2-3 times, full choke and it starts within 1-3 pulls. I like the decomp. I would take it back and have the dealer check it.
Good saw overall...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2025 25ft 1 Gauge 800 Amp Booster Cables (A50323)
2025 25ft 1 Gauge...
43030 (A51691)
43030 (A51691)
2015 Dodge Charger AWD Sedan (A50324)
2015 Dodge Charger...
2018 Chevrolet Traverse LT SUV (A50324)
2018 Chevrolet...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
