Steering Ball Joints for NH 1215
   / Steering Ball Joints for NH 1215 #1
Deaf
NE Ohio
Ford New Holland
I need two steering linkage ball joints for a 1215 New Holland(1996). Stopped at Napa hoping they could cross reference them but had no luck. Is there anyplace to get these type of parts besides a NH dealer?
   / Steering Ball Joints for NH 1215 #2
I would use a pitman remover and take a joint out during downtime (say winter), then I take it to auto part store. I bit you can find replacement. If the ball size is right then the length, Dia, and bolt size can be taken care off (modified)if you can not find exact OEM replacement.
JC,
p.s. if the ball joint is pressed hard beyond pitman, I would either make a hydraulic press out of couple of sticks of all thread and couple of pieces of uni- strut with a two ton bottle jack or use vice, anvil for support and piece of flat aluminum bar and a 4 LB hammer to drive the joint out.
Thanks for the Tips
Down time is now, the ball joint at the axle busted in half while moving a load of dirt. I was able to get the joint out so now looking for a replacement. Took the part into Napa thinking they would have something close. They counter guy must have been having an off day did not seem to want to look for me. I値l try another local shop tonight if not will order it from NH.
   / Steering Ball Joints for NH 1215 #4
Ya know.. there is a fixed front axle, 2wd, a power steering option, and a 4wd option.. you didn't provide any of that info.. which woulda made searching easier...IE.. not looking thru 3 diagrams to find parts are the same or not.
Shows as available from CNH...
SBA334801220 END ASSY. End, Tie Rod, R.H. Includes: Ref. 20 thru 23, Start Year: 01/01/1987
SBA334801240 END ASSY. End, Tie Rod, L.H. Includes: Ref. 20 thru 23, Start Year: 01/01/1987
Soundguy
Thanks Sound Guy
I was really looking for a parts source not the part but since you asked, it痴 a 4wd, no power steering. Thanks for the research I appreciate it.
Deaf
   / Steering Ball Joints for NH 1215 #6
CNH is the parts source.. i wouldn't expect there to be a huge demand for multiple aftermarket parts sources for a limited run machine like that....
soundguy
SG,
Went back to NAPA and got a good counter tech this time. We spent a good 10 minutes measuring and looking through parts books. Found one tie rod end that would fit all the threads and taper but was a tad bit to long and the savings just did not justify taking a chance. I ordered the OEM parts today from a local NH dealer, $46.08 for one and $43.00 for the other. I guess thats a fair price for a part on such a small volume tractor as you stated.
Deaf
   / Steering Ball Joints for NH 1215 #8
Sounds like a decent price to me. I replaced a TRE on a deer 2240 a while back and it cost what you paid for the 2 of yours together.. Probably 45$ of it was the part, and the other 45$ was for the green paint...
Soundguy
Kubota SVL95-2 High Flow Cab Skid Steer (A53473)
Kubota SVL95-2...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51691)
2015 Ford F-550...
CAT CHALLENGER 65B (A53843)
CAT CHALLENGER 65B...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
Halla LF30C 6,500lb LP Forklift (A51691)
Halla LF30C...
