Emperor
I have a JD 3203 Compact and was wondering why my steering was drifting after cutting grass. Noticed hydraulic fluid was spewing from the Power Steering Cylinder "Rod Guide" seal. Looks like a stick or something may have stabbed/got jammed between rod and rod guide and damaged the seal.
Noticed that the Rod Guide on my model, matches several other models. Also noticed the part alone is very expensive (almost $300). As ridiculous as that is, the tractor is useless while that is broken.
1. This looks like a fairly simple task. Is it?
2. If so, what is the basic procedure for disassembly and replacement of that part?
3. Should I consider an issue with the piston as well? It's expensive too!
Thanks!
Thanks!
