steering fluid question
   / steering fluid question #1
shawn092080
paw paw, mi
ford 3000
hi, i'm new to forum i have a ford 3000 tractor with the selecto speed trans. I had to replace the seals in the stearing column and can't find anything to tell me exactly what type of fluid i need to put back in it.
   / steering fluid question #2
:welcome: to TBN from Ohio. Post this in the Ford forum
   / steering fluid question #4
put in a utf meeting m2c134 spec ( hust about all of them do.
In reality. a good pump and seals would likely run on anything from atf to real 'ps' fluid, to 10w30 engine oil all the way up to 30w engine oil.. and most of the iso 32/46/64 plain hyd oils, including straight jack oil.
it's just not a real picky system.
go with utf..... you can top the sos off with it too.. etc
   / steering fluid question #5
Welcome to TractorByNet!
I moved your thread to the Oil, Fuel, & Lubricants forum. :)
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
2023 Caterpillar 299D3 High Flow XPS Compact Track Loader Skid Steer with CAT GB124 Grader Blade (A52377)
2023 Caterpillar...
2006 Crimson Spartan Fire 105ft. Quint Ladder Aerial Truck (A52377)
2006 Crimson...
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
