Steering Leak
   / Steering Leak #1
ken324
Clayton, OK
Ford Model NAA
The left side sector shaft seal is leaking on my Ford Golden Jubilee. The previous owner who has essentially rebuilt the box said that the shaft is worn and that is causing the leak. That said, I thought replacement shaft and then the vision of a complete teardown with all new seals, bushings, etc. came to mind. I would like to not have heavy oil dripping all over so something needs to be done. If replacing the shaft is necessary, can I remove and replace the sector shaft without removal of the steering shaft and other sector shaft? Any suggestions would be appreciated.
   / Steering Leak #2
I posted to your other thread above, about using grease in the steering box to stop a leak. Good luck with this.
   / Steering Leak #3
if you replace the sector you will likely be doing both.
I'd simply fill the box with nlgi 0 # Ep grease.
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55301)
2023 NEW HOLLAND...
2015 SHOP MADE MANIFOLD TRAILER (A53843)
2015 SHOP MADE...
AUGER SKID STEER ATTACHMENT WITH 3 AUGERS (A53843)
AUGER SKID STEER...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
1269 (A50490)
1269 (A50490)
