Steering motor leaks on 5550 ford BH
   / Steering motor leaks on 5550 ford BH #1
Eric dwyer
rochester ny
72 ford 5550 backhoe
Steering motor leaks because Simone (b4)me tried to drill and pin steering shaft to stripped head gear of steering motor Origanaly thought that seal was bad from heat of weld After a week and countless phone calls I found seal etc replaced installed motor only to find out that the leak is coming from the hole drilled can't find shaft (to rebuild motor) or replacement motor so I brought motor to a welder to weld hole only to find after installing again fluid is now coming from top of shaft
Now the welder has motor apart and is trying to determine if fluid should even be in shaft and if not how it's reaching top and if so wich seal need replacing but I would like to purchase new used motor it's a designate pot style steering motor from a ford 5550 backhoe also common in ford 8000 and 9000 series tractors
Correction Saginaw pot style steering motor
Is there anyone that can help me find a Saginaw pot style steering motor for a 5550ford backhoe
2012 Freightliner M2 106 Dump Truck, VIN # 1FVACXBS3CHBJ4624 (A51572)
2012 Freightliner...
2015 CATERPILLAR 262D SKID STEER (A51246)
2015 CATERPILLAR...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
HARDEE RD60M LOT NUMBER 157 (A53084)
HARDEE RD60M LOT...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
