Steering Wheel Removal
   / Steering Wheel Removal #1
MasseyWV
Veteran Member
I'm trying to get the steering wheel off my Massey 135 tractor, but the jaws of my 3 jaw puller can't get a good bite due to the diameter of the rubber on the center hub.
Suggestions?
   / Steering Wheel Removal #2
Suggestions?
Back the nut out even with the top of the threads then take a hammer and hit the nut square on the top of the nut while some one else pulls up evenly on both sides of the wheel. works most every time.
I finally got the steering wheel off by using a hammer and a screwdriver to break away the rubber from around the metal hub so I could use my 3 jaw puller. Even then it was stubborn, so I had to apply a considerable amount of torque to it until I heard a "pop" as the steering wheel came loose.
Since I'm gradually restoring the tractor, the steering wheel is eventually going to be replaced with a new one, so chipping away the rubber around the center, while a radical move, isn't a problem.
   / Steering Wheel Removal #4
Another good way to try is to put a bearing splitter below the wheel and pull on that. The wheel should pop right off.
J
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A51039)
Hay Van FL-95 Bale...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
