Steiner - Replacing brake shaft seal
   / Steiner - Replacing brake shaft seal #1
SteinerGuy
Wakefield QC
Lamborghini Runner 450, Steiner S-20
On the S-20 / 420, is the brake shaft seal replaceable without pulling apart the transaxle? It looks like it pulls out from the exterior on the parts diagram, but, when I look at the unit, it almost seems like presses in from the inside of the gearcase (meaning you would have to dismantle it all), or it's a very narrow seal.
Thanks!
Well I gave it a shot - I was able to pull the seal out without any trouble without disassembly. It looked weird as the seal is so narrow - Dimensions are 1.375X1.00X0.25, SKF number 9826 / National 252277. Also pulled the main pump control shaft seal, SKF 6763, crosses to National 252277. Hopefully these stop the small leaks I have.
   / Steiner - Replacing brake shaft seal #3
One of your National numbers is wrong, but big deal. Put some heavy grease or silicone grease on the seal lips before installing to help avoid nicks.
prs
You're right, sorry:
SKF 6763 - National 474261
SKF 9826 - National 252277
Both seals stopped the leaks.
John Deere Gator Utility Cart (A50324)
John Deere Gator...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
IH 1300 Sickle Bar Mower (A50515)
IH 1300 Sickle Bar...
John Deere 850 Tractor (AS IS) (A50774)
John Deere 850...
