The kid
Elite Member
- Joined
- Apr 25, 2012
- Messages
- 3,888
- Location
- Middle Tennessee
- Tractor
- 1965 135 gasser, 1967 135 diesel
Todays electronics are so much more than when I was a kid. Everything now is electronic. Let's take the speedometer, tachometer, gas gauge, volts, etc. In modern tractors these little critters may exist behind that pretty instrument cluster facing. So what is a stepper motor? In a since, it's a vibrating switch clock. it rocks a tiny gear from side to side in a oval fashion to spin a nylon gear. That gear is geared to another reduction gear that has a shaft that a molded pointer is presses on. Voltage comes from your vehicles computer and pulses voltage to keep the gears running. So the gear is stepping side to side. Thus calling it a stepper motor.
Here's a few pictures. I recently had two fail on my 2005 GMC Sierra gauge cluster. Simple enough to fix, but why did it fail. Proof is in the pictures. There are two coils inside the small stepper motor on opposite sides. Voltage pulses back and forth creating electromagnetic fields thus stepping the gears in motion. The failure was simple but very hard to see with the naked eye. The copper wire wound coils are as thin or maybe thinner than a human hair. One of those coil failed and burnt open probably from a loose connection over time.
Checkout these pictures.
The first picture is of the coils. You cam see the one the left is the one that failed. The pointy ends are actually the solder points which would be on the outside bottom of the stepper motor. Each motor has four solder connections.
