Stihl ms 290
   / Stihl ms 290 #1
greenthumb
SE/Mid Michigan
tc40, exmark lazer Z
I need a new Stihl had a 290 worked it to death for the last 15 or so years. Was happy with it. Thinking of getting one with a 20 inch bar. The old had a 16 I still have it could switch but my question is will a 20 inch bar be too much for this machine. Most of cutting is downed trees for forte wood. Not. A lot of felling but a 20 in bar would be good on occasion.
   / Stihl ms 290 #2
I have a 290 with an 18" bar. I use it for firewood and also for cutting logs for my bandsaw mill. I think a 20" would be pushing it for the saw in my opinion. I'm pretty happy with the 18".
   / Stihl ms 290 #3
The Stihl literature lists 16", 18", or 20" bars for the MS290.
I bought one last year and it was fitted with a 20" bar off the shelf. The dealer said that most of his MS290 sales were with 20" bars. I don't do any sawing that would require a 20" bar, so in the interest of having a marginally lighter saw, I had the dealer switch the 20" bar for an 18" bar. So far, so good.
Steve
   / Stihl ms 290 #4
might want to try a skip tooth chain with longer bar done that for years to get more bbar on smaller saw
greg
   / Stihl ms 290 #5
I personally would not buy a MS290.
IMO there are far better saws for the money. My uncle had a MS290, and it was VERY slow for its displacemet and weight. Heavy and slow are not desirable in a saw:confused2: This was just my own personal experience. Maybe it was a lemon of a saw:confused: Maybe it was just the chain combo:confused: Who knows. But running a MS310 right beside it, the 310 was considerabally faster for not much more $$ and not a ton more power on paper.
If you are a die-hard stihl man, I'd look into the MS260. Pro-grade saw, with nearly the same power as the 290 (3.75 vs 3.80) in a much lighter package. Or consider jumping to the 361/362 if you are going to be needing a 20" bar most of the time.
If you are not a diehard stihl man, shop around. Performance wise, stihl is about the most $$$ per HP. Husky, Dolmar/makita, Echo...all make excellent products. Check out a dolmar 5105 or 6400, or a husky 357.
   / Stihl ms 290 #6
The MS260 has been replaced with MS261.
The 357xp small mount is being replaced by 562xp large mount
290 replaced with 291
310 replaced by 311
Best money for the buck with auto carb tune for a homeowner with pro quality build husky 555 replaced the 359 in homeowner non xp saws.
The 555 is a small mount non xp saw like 560xp without the rev boost. Light and super fast cutting per a tester on Chainsawrepair. He said he sold the saw after all the testing for $475 shipped. 555 outcut the 357xp easily.
If you get another MS290 I seen they were on sale for $369 with so called free case. If you would do a simple 30min muffler mod and carb retune you will gain min 20% faster cutting speed with the stock rm? chain that comes with them. If you would slap on a stihl rsc chain you will gain about another 40% quicker cut. So you see it is easy to gain 60% quicker cuts for little time and good chain. Square file that rsc to a rslk and you gain another 10%. I seen 73% faster cut times with a stock MS290 I started with once after mod and changes.
I'm not a fan of a 290, but if your going to run one open it and make it run right, not the epa slitted muffler crap they sale you.
If you can find a MS361 new left over or used ($589 new, $300-$350 used) that was my favorite stihl in that range 59cc and cut circles around a 290 310. I would go used 361 all day over a new 290.
   / Stihl ms 290 #7
310 replaced by 311
Right on about that muffler mod.
I've had a 290 for about 10 years. Several years ago I modded the muffler. What a difference !
I also have a Husky 395XP for my Logosol mill. I modded the muffler on it as well about the same time. Talk about a beast !
(As a side note; if you didn't wear ear protection before, after the muffler mod, you will surely want to.)
(Another side note; no matter what brand or size saw you have, the one thing that you can do that will make a tremendous difference is KEEP THAT CHAIN SHARP !)
   / Stihl ms 290 #8
I do not have a 361 (I have a 357XP and an 044), but from what I read the 361 is far far better than the 290. But of course it costs more.
   / Stihl ms 290 #9
I researched this very topic in great detail about 2 years ago. I went with the 361 with a 20" bar and rsc chain. This is a professional grade saw that, while about the same weight as the 290, has MUCH more power and MUCH less vibration.
I am very happy with my choice and recommend the 361/362 for all but the largest jobs. :thumbsup:
   / Stihl ms 290 #10
I had both a woods ported 357xp and a stock muffler modded MS361. To wake up the animal inside a 361, do a simple muffler mod too and carb richen afterwords. Totally different saw then.
PHO only weight they both weigh less then 290 by almost half pound.
Husqvarna 357xp pop up domed piston woods ported testing - YouTube
weighed as used full of fluids and 16" b+c
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A48561)
80in HD Tooth...
42in. Skid Steer Forks (A46502)
42in. Skid Steer...
(6) Front Tractor Weights (A46502)
(6) Front Tractor...
2096 (A46502)
2096 (A46502)
Mini Universal Trailer Mover (A46502)
Mini Universal...
JCB HM180T Hydraulic Breaker Excavator Attachment (A45336)
JCB HM180T...
