uglyboywith11fingers
Hope this is appropriate for this forum, after all, we are rural.
This morning I was out in our attached garage, using my air nailer/stapler to slap together some free-standing shelf units for my daughters basement storage area.
The air compressor (120v) kicked in, then started to stop & start and finally just buzzed. I quick like a bunny hit the switch, and started to scratch my head, when wifey burst into the garage from the house, telling me the computer was popping and fizzing and smoking. Into the house I go, smells like burnt electronics, so I grab my multi-meter to check the power. One phase is at 147volts, the other at 93volts.
I quick went for the main switch. After thinking about it for a minute, I opened the main switch box, and checked things out with the multi-meter. with the main sw. off, both phases are at 120v. Turned on the main sw, back to the 147 & 93 situation... so I left it off & called the power company.
Well, they checked things out & tell me they think the problem is with the underground service wiring from meter box to the transformer at the road... about 200 feet.
Likely a problem with the neutral, they say. They say that repeated frost heaving over the years (house built in mid 1960's) has probably damaged the wiring, they suspect the conductors may be direct buried, not in a conduit. They are in a metal conduit going into the ground from the meter box. 100 amp service, by the way.
They left me with some neat transformer/gizmo attached at the meter box which apparently can stabilize the power even if one of the conductors, hot or neutral, is completely open.
So, we have power again, and a different crew is scheduled to come out and further diagnose our predicament. So far, 2 PC's dead, laser printer dead, digital light timer dead.
So I have a couple questions for you power experts on the forum...
1. What do you think of the diagnosis so far ? A few years ago, my neighbour across the road who is on the same transformer, had power fluctuations that required the utility to replace the Y crimp-connectors up at the transformer, that connect both our houses to the transformer. Apparently an overheated connection. At that time we had not noticed any power fluctuations. My limited knowledge would lead me to suspect a bad connection somewhere rather than a sharp rock or something underground intruding on the service wiring.
2. I'm in Ontario... who is usually responsible for repair/replacement of this underground service wiring if that is the problem ?
thanks for any opinions,
Pete
Pete
