Stripped lug nut threads
   / Stripped lug nut threads #1
Dream Farmer
Western MN
Bobcat CT230
I have some lug bolts that are stripped due to end of bolt damaged. I want to run a tap through to repair any possible damage and get new bolts. Does anyone have the correct thread size for a CT230? I know they are 12mm but not sure if 1.25 or 1.5 threads
   / Stripped lug nut threads #2
Look and see if it will poke through unimpeded. My JD uses a certain length but they were had to get so I just got the next length up and they stuck through the hub a quarter inch. Not a problem. At least I can see if they are backing out at all.
   / Stripped lug nut threads #3
Take a good nut/bolt pair to your local dealer and go from there. I've never put much faith in stripped nut/bolt combo's - especially when dealing with wheel components.
   / Stripped lug nut threads #4
Fronts are 12mmx1.25, rears are 16mmx1.5
   / Stripped lug nut threads #5
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2006 X-L SPECIALIZED 40TON RGN (A50854)
2006 X-L...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
