Stripped threads
   / Stripped threads #1
Maine_Polack
Central Maine
Mahindra 6500 4WD
I have a grease fitting "hole" that is stripped out. I can push the zerk in and out the hole easily.
I do not want to take the thing apart, or I would and tap for the larger zerk.
Can purchase a thread insert, but also have to get kit, $25,...Naw.
Any ideas/tips would be appreciated:)
   / Stripped threads #2
I have found some barbed grease fittings at the auto parts store. Finding one that is the proper size that will fit into the hole and be snug enough to work, will be the hard part.
Dusty
   / Stripped threads #3
They sell self-tapping zerks. We use them on our loaders for that reason. They work very well when you find the correct size. Might be the same/similar to Dusty's recommendation.
   / Stripped threads
Thanks for the info! I did call a couple of local Auto part stores before I posted my question. They did not have a clue.
Went to the big city, (Bangor), today, and ran into the same thing.:confused: I will keep hunting.
It sure is nice to be able to tap such a vast knowledge base, as found on this site. I truly appreciate all the input:D
   / Stripped threads #6
Check the diameter of the hole using a drill bit and post it. I will check my supply and also in town. If I can find one, I will put it into the mail to you. Just let me know what size.
Dusty
   / Stripped threads
Very nice of you to do that. Will check the size tomorrow. Dark now.
   / Stripped threads #8
Send me a PM to remind me. I might not see the post.
Dusty
   / Stripped threads #9
I believe you can get zerk fittings with metric thread. Might be able to use a slightly larger metric. If you try this don't try to tap it or anything, just turn it in and leave it.
   / Stripped threads #10
I had a zerk that would not take grease, I took the zerk out and cleaned it out and grease went through it until I put it back in the part, then it would not take grease again, what now?
SANY SY75C EXCAVATOR (A51242)
SANY SY75C...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
John Deere GP Tractor (A50514)
John Deere GP...
Wolverine Mini Skid Steer Pallet Forks (A50514)
Wolverine Mini...
UNUSED AGT XZ20R EXCAVATOR (A51243)
UNUSED AGT XZ20R...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
