Stuck coupler on X465 mower drive shaft
   / Stuck coupler on X465 mower drive shaft #1
Todd NE WY
North East WY
JD 4320
As the title says I cannot get the collar to slide on the mower drive shaft to allow it to come off and the mower deck to come out. I had this problem a couple years ago but I messed with it long enough and it finally released. This time I spent about 3 hours trying everything I could think of. Does anyone have any tricks to get it loose so I can get the rebuild kit and fix it.
Thanks,
Todd
   / Stuck coupler on X465 mower drive shaft #2
Maybe spray it down with some PB blaster or even a light oil.
Then a small prybar to encourage it to slide.. carefully as to not damage it (further, if something is wrong that it needs rebuilt.
Try reaching the collar from the rear of the tractor as the non all-wheel-steer tractors I've found to be less strain and contortion of the body and arm/wrist action that way.
Any known reason that you think it needs a re-build (beyond that it doesn't seem to function right now)?
Biggest reason I think it needs rebuilt is this is the 2nd time the collar has locked up. Last time I took the snap ring out and disassembled it and cleaned it up. I figure that with the fact that they sell a rebuild kit there must be a need for it.
(INOP) FORD 8N / 9N TRACTOR (A51247)
(INOP) FORD 8N /...
2002 International 9200i Truck (A53472)
2002 International...
BUSH HOG 7007 LOT IDENTIFIER 103 (A53084)
BUSH HOG 7007 LOT...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2018 FREIGHTLINER...
2022 John Deere 8RT 410 Tractor (A53342)
2022 John Deere...
2014 Jeep Compass 4x4 SUV (A51694)
2014 Jeep Compass...
