Stuck Hydraulic lift
   / Stuck Hydraulic lift #1
buppy69
Platinum Member
Western NC
Hinomoto E2804, Hinomoto N239,
What would cause a 3 point hitch to stick in the up position?
Eugene
I don't know what that is.
Eugene
   / Stuck Hydraulic lift #4
The positon control lever is connected to the hydraulic valve which controls the three point hitch. Mhassett was refering to the rod linkage from your lever to the valve. Check your linkage to see if a nut came off or loosened up, if it did it will not allow your lever to actuate the valve.
   / Stuck Hydraulic lift #5
Could also be the 3ph drop rate valve is closed off. Most tractors have it just below the seat/between your legs. Turn it counter clockwise and see if the hitch drops.
   / Stuck Hydraulic lift #6
What kind of tractor? Different tractors have different idiosyncrisies (sp?).
I will check those things. It is a Massey Ferguson 130.
Eugene
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2239 (A51244)
2239 (A51244)
1270 (A50490)
1270 (A50490)
3 pt Post Hole Digger (A50515)
3 pt Post Hole...
1996 Dodge Ram 3500 (A50515)
1996 Dodge Ram...
