STX 38 Only Starts when carb is primed...brakes ineffective.
   / STX 38 Only Starts when carb is primed...brakes ineffective. #1
johnwilldo
Bronze Member
North Eastern Pennsylvania, Lehigh Valley
John Deere 2305
Hi,
This little workhorse starts fine when priming the carb and will restart well during the same day. It the mower sits for a day or two, the only way to get it to start is to prime the carb. When first running it does not idle well and surges up and down. After warm up or under mowing load, it runs fine. but will not run an slow idle.
It is a Kohler engine. Also, I guess I need to look at the brake system since they are really not effective on my hilly property.
Any suggestions?
   / STX 38 Only Starts when carb is primed...brakes ineffective. #2
I've had one do this to me before, sounds like you're engine isn't getting the amount of fuel it needs. Mine had a lagging fuel pump, so I replaced it And re adjusted the fuel air mixture on the carb and it ran fine.
   / STX 38 Only Starts when carb is primed...brakes ineffective. #4
To fix the brakes, look below the frame near the right rear wheel for a lock nut on a horizontal shaft pointing towards the RR wheel, it is what tightens the brake puck.....the locking nut has a tendency to back off over time as you cycle the brake pedal, and it needs to be tighened back up. A replacement lock nut or lock-tight might be needed. This is a pretty common issue on the STX machines, but easily remedied. That being said, the brakes are not that strong and are easily over-powered by the engine, so if you don't push in the clutch, it will just keep on going.......
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
Ford NAA Jubilee Tractor (A51039)
Ford NAA Jubilee...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
Small concrete mixer (A49461)
Small concrete...
P&H OMEGA 20-20 (A50854)
P&H OMEGA 20-20...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
