sudden engine shut down, fuse blown
   / sudden engine shut down, fuse blown #1
gravelman
Platinum Member
NH
Kubota 2650
hi folks, gravelman back with update on B2650 Kubota 2016 model. If you recall it started shutting down instantly when i applied the brake and SET THE BRAKE hold lever. I took the cowl off the dash, there is a safety switch that the brake hold lever engages... as soon as that happens the 5 amp fuse that controls safety switch system blows. I took that safety switch off and the tip was rusty and there was no clicking noise. Im not even sure what that saftey switch does... never knew it was there. I will go to Kubota Monday and get a new switch hoping it is the problem. I saw no chaffed wires or any other issue.
2016 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2016 CHEVROLET...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2010 Ford Fusion Sedan (A59231)
2010 Ford Fusion...
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
