suggestions wanted on post hole digger condition
   / suggestions wanted on post hole digger condition #1
weiser
Hey everyone!
I just bought a used Danuser F8 locally. It's crazy heavy, and I am really looking forward to trying it out.
I went to hook it up for the first time and discovered that it will not fit my Category 1 hitch (lower links too large). They make a hardware kit (pretty expensive) to replace the lower pins with Category 1 size, but the old category 2 pins are seriously rusted into the sockets (the attachment is like a long pipe or sleeve, about 8 inches long versus a threaded end on my other attachments).
The rust is not anywhere near a concern for the implement's strength, but I doubt I'll be able to pull these pins out of the sleeves.
Do you guys have any suggestions for another way to mate a category 2 implement onto a category 1 tractor?
Any remote chance there's someone out there with a category 1 F8 and a category 1-and-2 tractor who would be interested in swapping the hoop portion of the digger?
I'm punting here...
   / suggestions wanted on post hole digger condition #2
Cut them off and weld new cat 1 pins on... $5 and the cost of welding :thumbsup:
Don't over think it.
   / suggestions wanted on post hole digger condition #3
THe lift pins are held in with 7/16"x1-3/4" roll pins. Did you remove these?
Excellent point hosspuller. I agree, and appreciate the sentiment.
I don't know how to weld, and don't have a welder; but I do want to learn and get one very soon. Do you have a recommendation on type and brand?
I did think about looking for someone to do this for me. I'd sort of prefer to keep the PHD in original condition in case I want to resell it later, but I'm not dead set on it.
fluggies4, I did get the roller pins out prior to posting this, but thanks. I was lucky to notice them because they were filled with dirt/grease, and not obvious at first glance. They were tough enough to get out with penetrating oil, so I was very intimidated by the size of the link pins themselves.
Long story short here though is I took the "hoop" portion off and brought it to a farm supply store, and they got the rusted pins out with heat (after I had put penetrating oil on them for a couple days). I was surprised they got them since the length was over 5" inside the sleeve, tight with rust. When they got them out, we found that they were reversible!
I switched them around to the Cat 1 side (after a good clean, polish, and greasing) and put them on the tractor last night for practice run at a first dig. Now I have to replace the cutting teeth and the sheer pin (failed pretty easy, and may have been bad to start with).
I'll get this baby in the ground yet!!
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
5x7 DK Aluminum Tilt Trailer (A51572)
5x7 DK Aluminum...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
