Suzuki LT160 Problem
   / Suzuki LT160 Problem #1
PitbullMidwest
Platinum Member
SE Iowa
1998 Kubota L2900GST
My daughter's LT160 has been running very rough lately. I pulled the top off of the air box to check the filter and was surprised to find that the air box was about 1/2 full of gas. I bailed it out and it ran fine for a few days and then it started sputtering again. So, I opened the air box and it once again had gas in it.
It's obvious that the gas is coming from the carb, but I'm hoping someone can explain why and what needs to be done to correct it.
   / Suzuki LT160 Problem #2
It sounds like the float is sticking.
take the bowl off and see if there is any trash inside.
   / Suzuki LT160 Problem #3
Replace the needle valve and seat should keep it from leaking. If your gas is blended the ethanol has been creating havoc. More than likley the rubber tip on the needle valve has become hard and will not seal. The seat may be ok but you wan to inspect it good.
Thank you Skipholiday and Shot Gun for the suggestions, I'll check it out next weekend.
Curt
2021 KUBOTA SVL75-2 SKID STEER (A60429)
2021 KUBOTA...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
KUBOTA U55-5 EXCAVATOR (A59823)
KUBOTA U55-5...
1995 Jeep Wrangler 4x4 SUV (A59231)
1995 Jeep Wrangler...
2019 CAT 259D (A60462)
