Switch to 2320
   / Switch to 2320 #1
classic
Bronze Member
Has any one on here had a 4100 or 4110 and switched to a 2320? I've got 800 hours on my 4110 and thinking of the switch. Some things I don't like are the difficulty of hooking up the drive shaft for the mower and the hydraulic couplers for the loader. Don't seem to be near as handy as my 4110. And of course I would have to replace all my attachments ie loader, cab,front hitch. and mower. Lets have it boys.
   / Switch to 2320 #2
you would haft to custom oreder the cab because the 2320 does not have the cab option from John Deere but i heard the 2320 is more handy than bigger tractors also John Deere came out with the 303E seriess tractors
keep us updated
:cool:
   / Switch to 2320 #3
I have a 4110...
What would be the benefit of getting a 2320? I just can't see what it has that your 4110 does not:confused: You would be wasting money IMHO. Now trading it in on a 3x20...go for it!
   / Switch to 2320 #4
Recently, in about the last 2 weeks, there was a guy on here that traded either a 4100 or 4110 in on a 2720. So far I think he has been very happy with it. If you want to trade it in for something modern and you've got the money than I'd say go for it.
   / Switch to 2320
I really haven't figured out why they don't have a 20 Hp unit any more. None of the attachments available use any more than 20 HP.
   / Switch to 2320 #6
Simple...HorsePower SELLS;)
   / Switch to 2320 #7
Classic:
Unless you're dying to help the economy out of recession or it has been giving you lots of trouble or you just have the itch for something newer, I'd suggest keeping your current rig.
   / Switch to 2320 #8
I guess I have some experience for you. I had a 4100. Loved it, very maneuverable, nice little tractor. I wanted more PTO HP for a snowblower I built, and heavier tractor in general for loader operations, so two years ago I sold the 4100 and bought a 2520. Super tractor! The longer frame and more weight makes for a much more capable loader tractor. And just about enough HP for just about everything the tractor frame is capable of. Most every attachment I had for the 4100 fit the 2520, except I had to lengthen the driveshaft for power to the front quick tach for the blower. No big problem there. Here it is two years later and I find myself needing to upgrade the power again. I need enough for a small square baler (without wagon). Also looking forward to having a loader mounted to the frame at the sides and front again, like the 4100 was, and the 2520 was not. Look into the differences in the loader mounting. The 300CX mounts at the front of the tractor frame like your 410 loader does now. The 200CX loader mounts at the side pillars only. It is an interesting difference. Good luck.
   / Switch to 2320
Jim did your 410 loader fit as well. Thats one concern I have. My loader is like new and hate to spend 3 or grand if I don't need to. As far as the snowblower goes that stupid little 47 blower won't even make the 4110 work so I certainly don't need more power.
   / Switch to 2320 #10
Classic, no the loader did not transfer. The 2520 needs a 200CX loader. I could be wrong, but thats how it worked for me.
2013 Ford F-150 Crew Cab Pickup Truck (A46684)
2013 Ford F-150...
Lonestar Panel w/ Gate (A49339)
Lonestar Panel w/...
2014 Chevrolet Impala Limited Sedan (A48082)
2014 Chevrolet...
2017 Ford F-250 Super Duty Ext. Cab Pickup Truck (A46684)
2017 Ford F-250...
Farmall 200 2WD Tractor (A49251)
Farmall 200 2WD...
Tooth Bar (A49251)
Tooth Bar (A49251)
