synchro shuttle
   / synchro shuttle #1
mustelid
southeast michigan
okay, i have another question about the 2810. can someone explain how a sychro shuttle transmission works....and how it makes using a loader more effecient. when do you need to use the clutch?
thanks! /forums/images/graemlins/smile.gif
   / synchro shuttle #2
The shuttle is on the streering column. It is a lever that moves forward and back. To go forward you engage the clutch and push the lever forward and reliese the clutch. to go in reverse you engage the clutch and move the lever back and release the clutch. It is synchronised in that you can be rolling forward or back and you can still put it in gear as long as you engage the clutch.
The trans speeds are determined by the Range( 3-speeds-not synchro) and trans gears(4-speeds-synchro)
They work very smooth and work good for fel work
2022 Patriot 10ft. Enclosed Cargo Trailer (A45336)
2022 Patriot 10ft...
3000 Gallon Black Poly Water Tank (A45336)
3000 Gallon Black...
2013 Nissan Sentra SL Sedan (A46684)
2013 Nissan Sentra...
2014 Western Star 4700 T/A Day Cab Truck Tractor (A46683)
2014 Western Star...
2014 UTILITY DRY VAN TRAILER (A45677)
2014 UTILITY DRY...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A48561)
Kubota 24in Quick...
