synchromesh transmission?
   / synchromesh transmission? #1
dknarnd
Columbia County, PA
JD1010, JD B, TC40A (new)
How does this transmission work? Do you not have to stop to shift through the 4 gears? I assume you do have to stop to shift ranges. Again I assume you do have to stop (or nearly stop) to change direction.
Does anyone know the ground speed of the various ranges in this transmission for the 4530?
   / synchromesh transmission? #2
You can shift through the 4-speed just like a car, but you have to stop for the range gears and should stop to change directions, but it will slip in to reverse while still rolling forward. It's an easy to use transmission.
   / synchromesh transmission? #3
i just got my new set up a few days ago, 5500 4WD 6' cutter and bb, and i really like the transmission set up. it took a little getting use to but leaning is fun, sometimes
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
UNUSED FUTURE SKID STEER 4IN1 COMBO BUCKET (A51244)
UNUSED FUTURE SKID...
2014 CATERPILLAR CB54 XW SMOOTH DBL DRUM ROLLER (A51242)
2014 CATERPILLAR...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
1998 CATERPILLAR D250E OFF ROAD DUMP (A51242)
1998 CATERPILLAR...
2013 Jeep Patriot (A50324)
2013 Jeep Patriot...
