T190 left side control panel
   / T190 left side control panel #1
Ddorr
Bobcat T190, John Deere 260
I have a 2006 T190 that the LCD display on the left hand panel has stopped working. I went to the local Bobcat dealer and priced one out and was quoted $450, not a cheap item but still I need it. After talking to the parts guy he said it will need to be programed to the Bobcat. I was under the impression that this was just a plug in item. Does anybody know if this is true or has anybody replaced one of these? I would hate to have to drag it all the way to the dealer to have it programed.
   / T190 left side control panel #2
Left panel does not require any programing. Right side, if it is the Deluxe/Keyless panel, might have an update available for it but with the age of your machine it should not be needed, Right panel with a key has no programing either.
Thank you for the reply. My machine has SJC and Deluxe/Keyless panel. He said the hours had to be programed into the new panel also. I thought the hours were stored in the main controller?
   / T190 left side control panel #4
The hours are stored in the main controller, the left is only a display LCD and command buttons.
Thanks for the answer.
Miscellaneous Pex Water Line on Pallet (A46502)
Miscellaneous Pex...
3024 (A46502)
3024 (A46502)
Rims and Tires (A46502)
Rims and Tires...
(10) 20ft. 6 Bar Galvanized Continuous Panels (A46502)
(10) 20ft. 6 Bar...
90in. Work Bench (A49339)
90in. Work Bench...
2015 Takeuchi TW65 Series 2 Wheel Loader (A46502)
2015 Takeuchi TW65...
