T5C SSQA Conversion
   / T5C SSQA Conversion #1
jgriffin1720
monson, ma
Terramite T5C
Going to be doing a skid steer quick attach conversion on my T5C, starting this thread to post pics for everyone. I am fabricating everything except the quick attach adapter myself so I will post info as best as I can. the quick attach I am using I got off of ebay from river valley machine, weighs 85lbs, and was cheap enough that I couldn't make it myself for less if you counted my time. I am going to upgrade the curl cylinder to a 2.25 bore cylinder to get a little more curl force to make up for the difference in leverage with the quick attach. For the bucket I found a 60" skid steer bucket from tomahawk that only weighs 255lbs, and the capacity perfectly matches the lift capacity of a T5C, I will resize it so that it works better with the machine if necessary. I also plan to set it up with a fork rack, third function, and grapple either from Artillian attachments or I will make my own, borrowing from their design.
   / T5C SSQA Conversion #2
I did a QA on my T9. I would suggest that you temporarily weld a bar between both loader arms to maintain the spread before you dissasemble. Then tack your eyes to the QA while it is assembled and watch for metal movement. I reused the original bucket parts and had some movement issues because I didn't think ahead.
   / T5C SSQA Conversion #3
Well you have a lot of work ahead of you & I have been thinking also about how to make a conversion.
The big problem is how to keep the weight down & attach the single curl cylinder. I like the 85 pound weight & it does look well made.
The next puzzle is with the handles as close as they are & the cylinder needing to go between them. The upgrade to a 2.5 cylinder I hadn't thought of but I am wondering if that may be a bit much.
For myself I would try the original first & adjust if needed. I am looking forward to seeing your progress please take good pictures with measurements & part #.
I tried to find RIVER VALLY MACHINE on eBay they were sold out at this time. I then tried to look them up & couldn't find them. perhaps I missed it.
I think you will have a lot of interest in this. Keep us posted.
1994 FORD F450-SUPER DUTY FLATBED (A51222)
1994 FORD...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
Toro Zero Turn Mower (A50322)
Toro Zero Turn...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A51219)
2015 VOLVO VNL...
71066 (A49346)
71066 (A49346)
New JMR 78" Double Skidloader Grapple (A50774)
New JMR 78" Double...
