t7
   / t7 #1
dneufell
New Hampshire
2002 T7 Terramite
Hello All!
Thank you for letting me join your "little" group :) I just purchased a 2001 Terramite
t7 with a 3 cylinder Isuzu diesel 24 hp engine. The over all condition is decent (1400 hours) but the motor might be junk. It starts up instantly(4 sec of glow glugs) and runs with no smoke (also no coolant in the radiator). There was coolant staining all on top of the radiator and the rear freeze plug in the head was popped out. There was no cracks or staining on the outside of the block. I do not know if the head or block is cracked. I made a BIG mistake (jumped the gun!) of taking the head off because i thought it was just the head gasket was blown. I should have filled the radiator, changed the oil +filter and started it to see what is going on. So now I am going to put on a new head gasket and fix (resolder) the radiator and pop in a freeze plug. Longshot...maybe it will work. There is very little info about Isuzu engines. If not will the Kubota diesel/Honda v twin bolt right in? I am trying to figure out my next move.....Thank you very much....Dean
   / t7 #3
Well the good news is it starts, so compression is at least reasonable. I agree with jaotguy and your plan, might as well proceed as long as you are not seeing signs of catastrophic damage. When you get it reassembled and coolant leaks fixed, please post back with results.
   / t7
Just ordered a service and parts manual, gasket kit, thermostat, freeze plug,and tty head bolts ......:) Dean
   / t7
did some stuff :)
pics at photobucket......Terramite by Dean Neufell | Photobucket
------------------TERRAMITE--------------2002
buddy mcdow- tow home 280 miles round trip $280 :) thank you very much buddy!
pdf Terramite parts and matainance books - internet
isuzu parts manual 5887102615 $31 m+l engine 985-857-8000
isuzu service manual ide2260 $40 3LB1 3clyinder diesel
new freeze plugs -shaker auto
valves lapped- neufell machining
new valve seals-i made a tool out of delrin -shop
new head gasket $87
entire engine gaskets $233
new toque to yield head bolts $86
overheat temp switch $53
head back on... :)
add "t" for coolant thermo coupler
flush out engine block
b+r radiator pressure tested and side bracket soldered + new cap $65
solvent tank clean 2 pc valve cover and breather
all fluids and filters changed oil r85334 hydralic p551551 fuel 86386 + antifreeze
add "t" to oil pressure switch to run a pressure gage
add "t" to coolant sensor to run a temp gage
add wire to alternator to run a amp gage
new gages- oil pressure, coolant temp, amp gage ($30) shaker auto
3 idiot dash lights wires fixed
Chris hand made a cover for the 3 gage pack - old school :)
wiring fixed...reroute and enclosed in plastic wire loom
3 new outside switches with rubber covers
flip battery and reroute positive cable ...clean terminals and fill with acid
fix oil breather and diesel fuel cap (previous dip **** monkeys)
fix hand throttle - unstick w pb blaster
4 bushings and fender washers for roof cover -no more rattle
forward/reverse foot lever fixed and stops adjusted
fuel pump was after the filter(drooltards) reroute and place before master fuel filter
add metal diesel pre-filter
fix motor mount (remove and drill out holes to hold fuel filter housing with 2 bolts)
buy a tube of limited slip additive mojo for rear diff - shaker auto
ajust forward/reverse petal and fix pivot bolt- easy to drive now
1/4-20 lug nut 13/16 hex for wheel (shaker auto)
weld chains on for outriggers (twice :)
new seat with arm rests (northern tool) xwm1160 $140 really nice :)
3 red lenses for idiot lights Allied Electronics $20. (bought 12 pc)
fix brake band and hardware $110 55620 55613 22042 (next time go kart brake band)
make 2 spacers for brake stand-off neufell machining :)
1" x 3" pin for backhoe swing lock $8 r+r tool
fix front hood - reweld both nuts
remove ugly front hood latches- :)
metal covers for rear spool valves ($11+51) 15147 15148
weld up and 5/8 bore both front end tie rods (mcmaster)
weld up and 5/8 bore steering link neufell machining :)
make bronze center steering bushing - stock $30
center steering pin washer+machine nut 53081 $8 mcmaster
pin the center steering bushing and add 2 new grease fittings top+bottom
6 new grease fittings
magnet cup holder :) $5
make 3 tie rod sleeves (4 degree taper)
weld chains for outriggers
weld handle for boom lock- skull topper :)
sticker- front bucket controls 14204 $12.75
sticker- backhoe controls 14284 $13.65
weld 3 cracks in rear bucket
4 pointed teeth-rear bucket 10591 $28.00 each
roll pins for teeth 10530 $3.55
cold pressure wash entire Terramite! 7/3/15
drain out diesel fuel tank (yuck/water)
change pre diesel filter
pop rivit fire extinguisher on
sheetmetal screw on clamps for rake and shovel- very cool
pop rivit operation manual box to back of seat - factory look :)
change rear end gear oil and add limited slip additive
red saftey triangle - epoxy magnets on back
pull rear dive shafts and repack w/ grease
sawzall off 4 tires - wow!!! tuff job
fix rim dents(heat and beat) wire brush and da sand (100 grit)
paint inside of rims w/ silver por15 (fast acting/long lasting) lol
put on 4 new tires....fill w/rv antifreeze -50 gal- Wallyworld $2.67/gal)
shaker auto - 5 of each extra air, oil, hydrulic, diesel,pre fuel filters $170
new 40 amp breaker (bat to alt)
weld front bucket alittle
weld left foot petal crack
weld on thumb!!!! works great :) Linville Industrys shelby ohio $195
...........................left to do...................
2002 book
need a extra ignition key
ripper blade 19297 $350 looks very cool!
landscape blade 19370 $485 chris likes it
bolt on rod+tube for front bucket level
install piston seals- rear bucket 82051 $42.62
hydro hose socks
wrenches for packing nuts
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2012 Porsche Panamera Hatchback (A50324)
2012 Porsche...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
